萌新求助,openmv怎么同时识别最大和次大的色块。
# Blob Detection and uart transport import sensor, image, time from pyb import UART import json # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... yellow_threshold =(3, 53, 6, 47, 14, 77) # You may need to tweak the above settings for tracking green things... # Select an area in the Framebuffer to copy the color settings. sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. uart = UART(3, 115200) def find_max(blobs): max_size=0 for blob in blobs: if blob.pixels() > max_size: max_blob=blob max_size = blob.pixels() return max_blob def find_second(blobs): blobs.remove(max_blob) second_blob=find_max(blobs) return second_blob while(True): img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([yellow_threshold]) if blobs: max_blob=find_max(blobs) second_blob=find_second(blobs) print('sum :', len(blobs)) img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(), max_blob.cy()) output_str="[%d,%d]" % (max_blob.cx(),max_blob.cy()) #方式1 #output_str=json.dumps([max_blob.cx(),max_blob.cy()]) #方式2 print('you send:',output_str) uart.write(output_str+'\r\n') else: print('not found!')
请问怎么写才能同时识别最大和次大色块?谢谢各位大佬
你没必要写一个函数的。
所以你函数写的有问题,变量没有定义。
@kidswong999 请问remove那个是直接写到find_max函数里面吗
uart = UART(3, 115200) def find_max(blobs): max_size=0 for blob in blobs: if blob.pixels() > max_size: max_blob=blob max_size = blob.pixels() return max_blob while(True): img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([yellow_threshold]) if blobs: max_blob=find_max(blobs) blobs.remove(max_blob) second_blob=find_max(blobs) print(max_blob) print(second_blob) else: print('not found!')
@kidswong999 您好,按这个可是还是报相同的错误
因为如果只有一个色块,删掉了一个,就是空的数组,find_max函数就会报错。
find_max 函数改一下。
def find_max(blobs): max_size=0 max_blob = None for blob in blobs: if blob.pixels() > max_size: max_blob=blob print(max_blob) max_size = blob.pixels() return max_blob
@kidswong999 这个样子的话,输出0个或者2个都没有问题,但是只有1个色块时就会报错
是啊,second_blob是None,当然不能用来画框
@kidswong999 嗯嗯 谢谢你啦
