  • 大佬,这个是怎么回事?应该怎么解决?这是已经插上SD卡了,没插也是类似错误。为什么?
    • 你要发你的代码。
    • import pyb
      import sensor, image, time,utime
      import car
      from pyb import Pin
      from pyb import Timer
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.skip_frames(10)
      thresholds = [(0, 100, 23, 127, -128, 127),
                    (0, 100, -128, -20, 126, -128),
                    (0, 80, 0, -128, -8, -128)]
      size_threshold = 500000
      x_pid = PID(p=0.5, i=1, imax=100)
      h_pid = PID(p=0.05, i=0.1, imax=50)
      def func():
          car.run(50,50)
      m = [0,0,0]
      flag1 = 1
      flag2 = 1
      flag3 = 1
          if(time.ticks()<=2700):
              car.run(0,0)
          elif(time.ticks()<=3500):
              car.run(100,100)
          elif(time.ticks()<=4500):
              car.run(50,-50)
          elif(time.ticks()<=7500):
              car.run(100,100)
          elif(time.ticks()<=8500):
              car.run(50,-50)
          elif(time.ticks()<=9000):
              car.run(100,100)
              car.run(0,0)
          img.lens_corr(1)
              uart.write(code.payload())
              m=list(code.payload())
              if(m!=[0,0,0]):
                  print(m)
                  while(flag1):
                      if(m[0]=='1'):
                          blobs = img.find_blobs([thresholds[0]])
                              max_blob = find_max(blobs)
                              x_error = max_blob[5]-img.width()/2
                              h_error = max_blob[2]*max_blob[3]-size_threshold
                              img.draw_rectangle(max_blob[0:4])
                              img.draw_cross(max_blob[5], max_blob[6])
                              x_output=x_pid.get_pid(x_error,1)
                              h_output=h_pid.get_pid(h_error,1)
                              car.run(-h_output-x_output,-h_output+x_output)
                              k = h_error+500000
                              if(k>=16000):
                                  tim = time.ticks()
                                  while(tim+500>=time.ticks()):
                                      car.run(50,50)
                                  tim = time.ticks()
                                  while(tim+2000>=time.ticks()):
                                      car.run(0,0)
                                  tim = time.ticks()
                                  while(tim+1000>=time.ticks()):
                                      car.run(-100,-100)
                                          k = h_error+500000
                                          if k >= 1000:
                                              tim = time.ticks()
                                                  car.run(50,50)
                                              tim = time.ticks()
                                                  car.run(0,0)
                                              tim = time.ticks()
                                                  car.run(-100,-100)
                                                  if(m[1]=='2'):
                                                      blobs = img.find_blobs([thresholds[1]])
                                                          k = h_error+500000
                                                          if(k>=16000):
                                                              tim = time.ticks()
        car.run(50,50)
                                                              tim = time.ticks()
        car.run(0,0)
                                                              tim = time.ticks()
        car.run(-100,-100)
        k = h_error+500000
        if k >= 1000:
        tim = time.ticks()
        car.run(50,50)
        tim = time.ticks()
        car.run(0,0)
        tim = time.ticks()
        car.run(-100,-100)
        if(m[2]=='3'):
        blobs = img.find_blobs([thresholds[2]])
        k = h_error+500000
        if(k>=16000):
        tim = time.ticks()
        car.run(50,50)
        tim = time.ticks()
        car.run(0,0)
        tim = time.ticks()
        car.run(-100,-100)
        k = h_error+500000
        if k >= 1000:
        tim = time.ticks()
        car.run(50,50)
        tim = time.ticks()
        car.run(0,0)
        tim = time.ticks()
        car.run(-100,-100)
        car.run(50,-50)
        car.run(50,-50)
        car.run(50,-50)
                                                          car.run(50,-50)
                                                  if(m[1]=='3'):
                                                          k = h_error+500000
                                                          if(k>=16000):
                                                              tim = time.ticks()
        car.run(50,50)
                                                              tim = time.ticks()
        car.run(0,0)
                                                              tim = time.ticks()
        car.run(-100,-100)
        k = h_error+500000
        if k >= 1000:
        tim = time.ticks()
        car.run(50,50)
        tim = time.ticks()
        car.run(0,0)
        tim = time.ticks()
        car.run(-100,-100)
        if(m[2]=='2'):
        k = h_error+500000
        if(k>=16000):
        tim = time.ticks()
        car.run(50,50)
        tim = time.ticks()
        car.run(0,0)
        tim = time.ticks()
        car.run(-100,-100)
        k = h_error+500000
        if k >= 1000:
        tim = time.ticks()
        car.run(50,50)
        tim = time.ticks()
        car.run(0,0)
        tim = time.ticks()
        car.run(-100,-100)
        car.run(50,-50)
        car.run(50,-50)
        car.run(50,-50)
                                                          car.run(50,-50)
                                          car.run(50,-50)
                              car.run(50,-50)
    • @kidswong999 老板,这个怎么解决,麻烦啦。
    • @kidswong999 咱能不能具体问题给出一些具体的措施?你那个统一回复我还是不知道我这个程序该怎么改,怎么解决问题。
    • 根据我的猜测,可能是一次性代码太长了。
      在IDE里运行的时候,其实是通过串口把所有的代码文字传输给OpenMV,然后运行,好像是这个问题。
      解决办法:多模块编程,把任务分开,分割成不同的文件。
