  • 色块识别不同颜色最大的模块
    • 现在只能要么识别三个颜色所有的色块,要么只识别第一种颜色的最大模块,如何实现识别三个颜色最大的色块啊
      # Multi Color Blob Tracking Example
      # This example shows off multi color blob tracking using the OpenMV Cam.
      import sensor, image, time,math
      # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      # The below thresholds track in general red/green things. You may wish to tune them...
      thresholds = [(0, 31, -53, 50, -91, 107), # generic_red_thresholds
                    (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      # You may pass up to 16 thresholds above. However, it's not really possible to segment any
      # scene with 16 thresholds before color thresholds start to overlap heavily.
      X_relative_displacement=0
      Y_relative_displacement=0
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
      uart = UART(3,9600)
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
          blobs = img.find_blobs(thresholds, pixels_threshold=10, area_threshold=10)
              max_blob = find_max(blobs)
              img.draw_cross(max_blob.cx(), max_blob.cy())
              X_data = max_blob.cx()-img.width()/2
              Y_data = img.height()/2-max_blob.cy()
              if X_data >= 0:
                  X_Sign = 0
              if X_data <= 0:
                  X_Sign = 1
              if Y_data >= 0:
                  Y_Sign = 0
              if Y_data <= 0:
                  Y_Sign = 1
      #        X_data = max_blob.cx()-40
      #       Y_data = img.height()-max_blob.cy()
      #        if X_data<0:
      #            X_data=0
      #        if X_data>255
      #            X_data=255
              X_data=abs(X_data)
              Y_data=abs(Y_data)
              X_relative_displacement=int(X_data)
              Y_relative_displacement=int(Y_data)
              img_data = bytearray([0x2C,7,X_Sign,Y_Sign,X_relative_displacement,Y_relative_displacement,0x5B])
              uart.write(img_data)
              print(X_relative_displacement,Y_relative_displacement)
    • 三个阈值分别进行颜色识别并调用max函数。
      blobs = img.find_blobs(thresholds[0], pixels_threshold=10, area_threshold=10)
              max_blob_0 = find_max(blobs)
      blobs = img.find_blobs(thresholds[1], pixels_threshold=10, area_threshold=10)
              max_blob_1 = find_max(blobs)
      blobs = img.find_blobs(thresholds[2], pixels_threshold=10, area_threshold=10)
              max_blob_2 = find_max(blobs)
    • 蟹蟹啦,问题解决了
    • 可不可以分享一下识别不同颜色最大色块的程序啊,谢谢
    • 请问楼主你这个程序我调好了之后,想用串口发送是识别了哪种颜色的色块,为什么不能调用blob.code()
    • @anpo 新的问题,请单独提问。
    • @wyfg 可以分享一下代码吗
