  • 粘贴上了找的测距的代码,貌似出了点问题,请教各位大神该怎么处理
      # Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      yellow_threshold   = ( 56,   83,    5,   57,   63,   80)
      K=5000#the value should be measured
          if len(blobs) == 1:
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              length = K/Lm
              print(length)
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
    • 什么问题?😀
    • 我没找到运行结果,应该在哪里看结果,或者说是运行在25行中断了?
    • 代码里默认是先颜色识别获取目标物体像素,你得先调整颜色阈值
    • 谢谢你,但是我还是对这些不太懂。我在工具-机器视觉-阈值编辑器里调整了黑白颜色,然后还是不知道该怎么做。
    • 你看一下视频10,
      https://singtown.com/video/
