  • 还用定时器为什么会出现内存错误的这种情况啊?
    • sensor.reset() # Initialize the camera sensor.
      face_cascade = image.HaarCascade("frontalface",stages=25 )
      NUM_SUBJECTS = 3 #图像库中不同人数,一共6人
      NUM_SUBJECTS_IMGS = 3 #每人有20张样本图片
      flag=0
      def tick(timer):            # we will receive the timer object when being called
          flag=1
          for s in range(1,NUM_SUBJECTS+1):
              dist=0
              for i in range(1,NUM_SUBJECTS_IMGS+1):
                     img1=image.Image("/photos/s%d/%d.pgm"%(s,i))
          print("差异度为:%d"%pmin)
          print("Timer callback")
          if flag==0:
              img=sensor.snapshot()
              for r in objects:
                     img.draw_rectangle(r)
                     d0=img.find_lbp(r)
              if (len(objects)!=0):
                     tim = Timer(4, freq=1)      # create a timer object using timer 4 - trigger at 1Hz
                     tim.callback(tick)          # set the callback to our tick function
    • 请详细描述问题,
      包括,目的,步骤,报错提示
    • @kidswong999 我想用定时器实现到当采集到人脸信息时调用程序,去对比两张图片的LBP值,然后输出最匹配的那个人。但是出现了内存错误的提示0_1537693539396_039d148e-1fd6-494f-b4a7-d2bcf90d7f85-image.png
    • 这不是内存错误,你看看英文?
    • @kidswong999 0_1537693989653_1215f853-bebc-4926-8c51-d29647c7bf26-image.png 刚才是这个我重启了一下程上面那个了
