  • WIFI传图做色块识别,手机上看不到框框怎办
    • 手机上看不到把色块框起来的框框
    • 需要编写程序的,你把你的程序贴一下
    • 此回复已被删除!
      import sensor, image, time, network, usocket, sys
      from pyb import UART,LED
      uart = UART(3, 1382400) #设置串口波特率
      uart.init(1382400,timeout_char=100)
      green_threshold   = ((42, 78, 34, 82, 0, 63))#目标颜色
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      sensor.skip_frames(10)
      #sensor.set_auto_gain(False)
      #等待接收客服端连接成功
      while(uart.readchar()!=43):
          print("connect...")
      #连接成功LED显示
      LED(1).on()
      time.sleep(2000)
      uart.write("HTTP/1.1 200 OK!\r\n" \
                  "Server: OpenMV\r\n" \
                  "Pragma: no-cache\r\n\r\nend")
      # FPS clock
      time.sleep(4000)
      # Start streaming images
      # NOTE: Disable IDE preview to increase streaming FPS.
          cframe = img.compressed(quality=35)
          header = "\r\n--openmv\r\n" \
              max_blob = find_max(blobs)
          uart.write(header)
          uart.write(cframe)
          uart.write("end")
    • cframe = img.compressed(quality=35)
      这一句,需要放在后面,需要在draw_rectangle/draw_cross后面,才可以让画出框框的图像发送出去。
    • 谢谢你,我以后会常来这提问。谢谢。
