  • openmv3.0.0可以改变帧率么,。。遇到的问题是,识别数码管数字,数码管有频闪,导致识别结果错误。
    • # Template Matching Example - Normalized Cross Correlation (NCC)
      # image patches to parts of an image... expect for extremely controlled enviorments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will reamin to show
      import time, sensor, image
      # Reset sensor
      # Set sensor settings
      # Load template.
      template0 = image.Image("/0.pgm")
      template1 = image.Image("/1.pgm")
      template2 = image.Image("/2.pgm")
      template3 = image.Image("/3.pgm")
      template4 = image.Image("/4.pgm")
      template5 = image.Image("/5.pgm")
      template6 = image.Image("/6.pgm")
      template7 = image.Image("/7.pgm")
      template8 = image.Image("/8.pgm")
      template9 = image.Image("/9.pgm")
      # Run template matching
          r0 = img.find_template(template0, 0.7, roi=(50,20,60,80), step=4, search=SEARCH_EX)
          r1 = img.find_template(template1, 0.7, roi=(50,10,70,100), step=4, search=SEARCH_EX)
          r2 = img.find_template(template2, 0.7, roi=(50,10,70,100), step=4, search=SEARCH_EX)
          r3 = img.find_template(template3, 0.7, roi=(50,20,60,80), step=4, search=SEARCH_EX)
          r4 = img.find_template(template4, 0.7, roi=(50,10,70,100), step=4, search=SEARCH_EX)
          r5 = img.find_template(template5, 0.7, roi=(50,20,60,80), step=4, search=SEARCH_EX)
          r6 = img.find_template(template6, 0.7, roi=(50,20,60,80), step=4, search=SEARCH_EX)
          r7 = img.find_template(template7, 0.7, roi=(50,10,70,100), step=4, search=SEARCH_EX)
          r8 = img.find_template(template8, 0.7, roi=(50,10,70,100), step=4, search=SEARCH_EX)
          r9 = img.find_template(template9, 0.7, roi=(50,10,70,100), step=4, search=SEARCH_EX)
          #img.draw_rectangle(ROI)
          if r0:
              a=0
          elif r1:
              a=1
          elif r2:
              a=2
          elif r3:
              a=3
          elif r4:
              a=4
          elif r5:
              a=5
          elif r6:
              a=6
          elif r7:
              a=7
          elif r8:
              a=8
          elif r9:
              a=9
              a=1111111
          print(a)
      ![0_1534745779456_1.png](https://fcdn.singtown.com/93cb70e4-ed14-47bd-ab9e-34c3cf6a2828.png)
    • 这不是OpenMV 帧率的问题。
      OpenMV 的快门时间是远远小于你的数码管”轮循LED”的。(摄像头都这样的,如果快门时间能等数码管,那果冻效果太严重了)
      尽量从数码管上想办法。不要用片选-轮循的方法显示多位数码管。多用几个io,独立控制每个数码管。
    • 你好,如果数码管的频率改不了,针对openmv有什么方法或者思路吗?
    • 改OpenMV的曝光时间。
