多色识别不同追踪
当收到“a”时开启颜色识别,识别到不同颜色执行不同程序,小车有不同的反应,但是一开启摄像头老是识别到不是你设点的颜色,不知道为啥?急用,请帮我看下,非常感谢
This example shows off how to use the find_blobs function to find color
blobs in the image. This example in particular looks for dark green objects.
uart = UART(3,9600)
import car
sensor.set_auto_gain(False)
clock = time.clock() # Tracks FPS.For color tracking to work really well you should ideally be in a very, very,
very, controlled enviroment where the lighting is constant...
green_threshold =(63, 38, 15, -65, -11, -112)
red_threshold =(41, 13, -78, -13, -24, 72)
blue_threshold =(10, 36, -18, 17, -19, 13)
size_threshold = 10000
x_pid = PID(p=0.5, i=1, imax=100)
h_pid = PID(p=0.05, i=0.1, imax=50)def find_max(blobs):
return max_blobYou may need to tweak the above settings for tracking green things...
Select an area in the Framebuffer to copy the color settings.
if(uart.any()):
data = uart.readline()
print("reseived:",data)
if data.decode().startswith('a'):
img = sensor.snapshot() # Take a picture and return the image.blob1 = img.find_blobs([green_threshold]) blob2 = img.find_blobs([red_threshold]) blob3 = img.find_blobs([blue_threshold]) if blob1: max_blob = find_max(blob1) x_error = max_blob[5]-img.width()/2 h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error) ''' for b in blobs: # Draw a rect around the blob. img.draw_rectangle(b[0:4]) # rect img.draw_cross(b[5], b[6]) # cx, cy ''' img.draw_rectangle(max_blob[0:4]) # rect img.draw_cross(max_blob[5], max_blob[6]) # cx, cy x_output=x_pid.get_pid(x_error,1) h_output=h_pid.get_pid(h_error,1) print("h_output",h_output) car.run(-h_output-x_output,-h_output+x_output) print("a") elif blob2: max_blob = find_max(blob2) x_error = max_blob[5]-img.width()/2 h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error) ''' for b in blobs: # Draw a rect around the blob. img.draw_rectangle(b[0:4]) # rect img.draw_cross(b[5], b[6]) # cx, cy ''' img.draw_rectangle(max_blob[0:4]) # rect img.draw_cross(max_blob[5], max_blob[6]) uart.write("b") time.sleep(1000) uart.write("c") print("10") time.sleep(3000) print("11") #for i in range(100000): car.run(30,-30) elif blob3: max_blob = find_max(blob3) #x_error = max_blob[5]-img.width()/2 #h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error) ''' for b in blobs: # Draw a rect around the blob. img.draw_rectangle(b[0:4]) # rect img.draw_cross(b[5], b[6]) # cx, cy ''' #img.draw_rectangle(max_blob[0:4]) # rect #img.draw_cross(max_blob[5], max_blob[6]) print("T") car.run(0,0) break else: car.run(30,-30) print("b") else: car.run(0,0) else: car.run(0,0)
如何设定颜色阈值的问题,请看教程
但是我,一个颜色就不会,多个颜色就会
@kidswong999 你帮我看下程序可以吗,我怕程序写漏了什么,非常感谢,急用
我没懂你是什么意思,你的问题是什么?
@kidswong999 就是它老是别别的颜色识别进去,你可以帮我看下,程序那里出错了吗?需要怎么改
请回答以下问题
你的代码要实现什么功能,应该有什么现象?
你的代码现在有什么故障,什么现象现象?你认为是代码的哪里有问题?
程序的逻辑是否用流程图设计过?
你又做了什么来检查问题?
我觉得应该是阈值的问题,我那程序阈值的设置和调用大概是这样子,你帮我看下阈值这样设,对不对
blue_threshold =(10, 36, -18, 17, -19, 13)blob1 = img.find_blobs([green_threshold])
blob3 = img.find_blobs([blue_threshold])if blob1:
程序1
elif blob2:
程序2
elif blob3:
程序3
程序4
你说的没错,可是你也没回答我的问题
@kidswong999 让它识别到不同的颜色,执行不同的运动,当收到a时,开启颜色识别,当检测到绿色,跟着绿色走,红色的话,让他发送一个b,延时后再发送一个c,蓝色的话先停止然后结束,因为a只发了一次,所以这时跳出判断后,就不会再进行颜色识别,检测绿色是,打印一个a,可以在终端看执行程序那部分,同理蓝色时打印10,11也是,代码没有错误,但是运行的时候,你没把绿色,蓝色放在摄像头里,它老是把别的颜色识别进去。你可以把程序烧进去看下,就很快知道怎么回事了
你应该自己调试,你可以print 来看你的逻辑执行的过程
