  • 江湖救急,求教树莓派Raspbian安装OpenMV IDE的方法!
    • 想要通过树莓派和Openmv实现远程编程和调试,个人水平有限,参考gayhub上在Pi3B上编译安装IDE的教程,在Raspbian(Jessie)上安装失败,能否可以提供在树莓派上详细的安装办法呢(MD文档应该是在Pi的Ubuntu下安装的,并且Raspbian里安装Qtrpi都不顺利)
      还有就是希望能够提供通过源码编译IDE的教程……
    • 其实我没用过树莓派上安装OpenMV的IDE,有空我试一试。。。
      直接双击执行文件不行吗?为什么要编译?
      https://singtown.com/openmv-download/
    • 谢天谢地~刷了stretch之后居然顺利安装成功了!!!!
      切换的清华的国内源,校园网被墙,不过速度很快,依赖包都可以载下来。
      之前jessie版本的总是在pyusb这一步卡住,这次也报了几个异常,不过连接上板子之后试试了试暂时没有发现什么问题。
      下面是返回的一些异常,不知道在不同的系统中安装会不会有区别,供参考吧,虽然不懂😂
      Exception:
      Traceback (most recent call last):
        File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 215, in main
          status = self.run(options, args)
        File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 353, in run
          wb.build(autobuilding=True)
        File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 749, in build
          self.requirement_set.prepare_files(self.finder)
        File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 380, in prepare_files
          ignore_dependencies=self.ignore_dependencies))
        File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 620, in _prepare_file
          session=self.session, hashes=hashes)
        File "/usr/lib/python2.7/dist-packages/pip/download.py", line 821, in unpack_url
          hashes=hashes
        File "/usr/lib/python2.7/dist-packages/pip/download.py", line 659, in unpack_http_url
          hashes)
        File "/usr/lib/python2.7/dist-packages/pip/download.py", line 853, in _download_http_url
          stream=True,
        File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
          return self.request('GET', url, **kwargs)
        File "/usr/lib/python2.7/dist-packages/pip/download.py", line 386, in request
          return super(PipSession, self).request(method, url, *args, **kwargs)
        File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
          resp = self.send(prep, **send_kwargs)
        File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
          r = adapter.send(request, **kwargs)
        File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
          resp = super(CacheControlAdapter, self).send(request, **kw)
        File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
          timeout=timeout
        File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
          _stacktrace=sys.exc_info()[2])
        File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
          total -= 1
      TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
      运行图:
      无线连路由器,远程桌面调试美滋滋:
    • 之前编译是看了GitHub中的OpenmvIDE编译源码方式运行IDE的?
      另外就是想研究一下算法的源码,IDE里好像是无法查看和修改源码的吧,通过修改源码,然后重新编译生成IDE?我是这个思路,自己挖坑自己跳……
      QtRpi的安装也很麻烦,记得最后貌似也是卡在了pyusb这里,官方给出的编译环境是Ubuntu64。
    • 算法的源码。。。和IDE一点关系都没有,你应该编译固件。
      https://forum.singtown.com/topic/69/sensor-模块的源码在哪里-怎样查看-谢谢
    • 希望出一个教程,尝试了好多方法都失败了
