  • 为什么识别到图像后数据通过串口发不到stm32上去
    • 请在这里粘贴代码import sensor, image, time
      from machine import UART, Pin
      import struct
      # 硬件初始化
      sensor.skip_frames(2000)
      sensor.set_auto_gain(False)
      # 颜色阈值 (LAB格式)
      red_threshold = (56, 14, 70, 37, -30, 46)    # 红色
      yellow_threshold = (46, 100, -68, 72, 58, 92) # 黄色
      # 外设初始化
      uart = UART(1, baudrate=115200, timeout_char=100)
      led = Pin("LED_RED", Pin.OUT)  # 使用板载LED作为传输指示灯
      # 传输统计变量
      success_count = 0
      fail_count = 0
      last_status = None
      def send_to_stm32(obj_type, x, y):
          """发送协议帧并返回状态"""
          global success_count, fail_count, last_status
              # 数据打包(小端格式)
              packet = struct.pack('<BiiB',
                                  obj_type,  # 1字节类型
                                  int(x),    # 4字节X坐标
                                  int(y),    # 4字节Y坐标
                                  0xAA)      # 结束符
              # 清空缓冲区
              while uart.any():
                  uart.read()
              # 发送数据(LED亮起)
              led.on()
              uart.write(packet)
              # 等待确认(300ms超时)
              start = time.ticks_ms()
              while time.ticks_diff(time.ticks_ms(), start) < 300:
                  if uart.any() and uart.read(1) == b'\x55':
                      success_count += 1
                      last_status = True
                      led.off()
                      return True
              # 发送失败处理
              fail_count += 1
              last_status = False
              led.off()
              return False
          except Exception as e:
              print("Send error:", e)
              fail_count += 1
              last_status = False
              led.off()
              return False
      def display_status(img):
          """在图像上显示传输状态"""
          # 状态文字颜色
          color = (0, 255, 0) if last_status else (255, 0, 0)
          # 绘制状态信息
          img.draw_string(0, 0, f"TX: {'OK' if last_status else 'FAIL'}",
                         color=color, scale=2)
          img.draw_string(0, 20, f"Success: {success_count}",
                         color=(0, 255, 0), scale=1)
          img.draw_string(0, 40, f"Fail: {fail_count}",
                         color=(255, 0, 0), scale=1)
          img.draw_string(0, 60, f"FPS: {clock.fps():.1f}",
                         color=(255, 255, 0), scale=1)
          # 红色圆形检测与发送
          red_sent = False
          for c in img.find_circles(threshold=3500, r_min=2, r_max=100):
              area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r())
              stats = img.get_statistics(roi=area)
              if (0 < stats.l_mode() < 100 and
                  0 < stats.a_mode() < 127 and
                  0 < stats.b_mode() < 127):
                  img.draw_circle(c.x(), c.y(), c.r(), color=(255,0,0))
                  if not red_sent:  # 避免重复发送
                      send_to_stm32(0x01, c.x(), c.y())
                      red_sent = True
          # 黄色块检测与发送
          yellow_sent = False
          for b in img.find_blobs([yellow_threshold]):
              img.draw_rectangle(b.rect(), color=(255,255,0))
              img.draw_cross(b.cx(), b.cy(), color=(255,255,0))
              if not yellow_sent:
                  send_to_stm32(0x02, b.cx(), b.cy())
                  yellow_sent = True
          # 显示传输状态
          display_status(img)
          # 调试输出
          if clock.fps() > 10:  # 控制打印频率
              status = "Success" if last_status else "Fail"
              print(f"{status} | Success: {success_count} Fail: {fail_count} FPS: {clock.fps():.1f}")
