怎么修改这个二维码的程序使二维码的内容在LCD中显示(纯小白,请大佬揉碎了喂嘴里)
import sensor, image sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) # can be QVGA on M7... sensor.skip_frames(30) sensor.set_auto_gain(False) # must turn this off to prevent image washout... while(True): img = sensor.snapshot() img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens. for code in img.find_qrcodes(): print(code)
@ztrp import sensor, image
import lcd
sensor.set_framesize(sensor.QQVGA2) # can be QVGA on M7...
sensor.set_auto_gain(False) # must turn this off to prevent image washout...while(True):
img.draw_string(10,10,code.payload())
lcd.display(img)
这个有报错 'image' imported but unused
no module named 'lcd'
固件版本太高,lcd库被删除了,就会报没有lcd这个库,现在都换成display库了
@avqs 把lcd换成display吗
