  • LCD使用的display库的资料请问在哪里找?以下两行代码在display库中怎么替换?
    • lcd.display(img,x_size=320)
      lcd.init(width=320,height=240,triple_buffer=False,rbg=True)
    • 如果使用自己的LCD屏,帧率特别低应该如何调整?
      #函数名: myLCD.py 要把这个函数和主函数一起放在OpenMV的根文件中(也就是U盘)才可以互相调用。
      from pyb import Pin, SPI
      cs  = Pin("P3", Pin.OUT_OD)
      rst = Pin("P7", Pin.OUT_PP)
      rs  = Pin("P8", Pin.OUT_PP)
      bl  = Pin("P6", Pin.OUT_PP)     # 背光控制
      spi = SPI(2, SPI.MASTER, baudrate=20*1000000, polarity=1, phase=0,bits=8)
      # SPI 写命令
      def write_command_byte(c):
          cs.low()
          rs.low()
          spi.send(c)
          cs.high()
      # SPI 写数据
      def write_data_byte(c):
          cs.low()
          rs.high()
          spi.send(c)
          cs.high()
      def write_command(c, *data): #命令数据一起写,先写命令 第二个开始为数据位。如果只写一个,则代表不写数据只写命令。
          if data:
              for d in data:
                  if d > 255:
                      write_data_byte(d >> 8)
                      write_data_byte(d&0xFF)
                      write_data_byte(d)
      def write_image(img):
          cs.low()
          rs.high()
          fbuf = bytearray(320)
          for m in img: 					#把一帧图像的对象取出来,放到帧缓存区中
              fbuf=m
              for i in range(0,320):		#每行每行的发送
                  spi.send(fbuf[i]>>8)	#先发第N行的第I个数据的高八位
                  spi.send(fbuf[i]&0xFF)	#再发低八位
          cs.high()
      def SetRegion(xStar, yStar, xEnd, yEnd):
          write_command(0x2A, xStar>>8, xStar&0XFF, xEnd>>8, xEnd&0XFF)
          write_command(0x2B, yStar>>8, yStar&0XFF, yEnd>>8, yEnd&0XFF)
          write_command(0x2C)
      def LCDinit():
          rst.low()
          time.sleep_ms(100)
          rst.high()
          time.sleep_ms(100)
          write_command(0xCB, 0x39, 0x2c, 0x00, 0x34, 0x02)
          write_command(0xCF, 0x00, 0XAA, 0XE0)
          write_command(0xE8, 0x85, 0x11, 0x78)
          write_command(0xEA, 0x00, 0x00)
          write_command(0xED, 0x67, 0x03, 0X12, 0X81)
          write_command(0xF7, 0x20)
          write_command(0xC0, 0x21)       # Power control, VRH[5:0]
          write_command(0xC1, 0x11)       # Power control, SAP[2:0];BT[3:0]
          write_command(0xC5, 0x24, 0x3C) # VCM control, 对比度调节
          write_command(0xC7, 0xB7)       # VCM control2, --
          write_command(0x36, 0xE8)
          X_MIN_PIXEL = 0
          Y_MIN_PIXEL = 0
          X_MAX_PIXEL = 320               # 定义屏幕宽度
          Y_MAX_PIXEL = 240               # 定义屏幕高度
          SetRegion(0, 0, X_MAX_PIXEL - 1, Y_MAX_PIXEL - 1)
          write_command(0x3A, 0x55)
          write_command(0xB1, 0x00, 0x18)
          write_command(0xB6, 0x08, 0x82, 0x27)   # Display Function Control
          write_command(0xF2, 0x00)               # 3Gamma Function Disable
          write_command(0x26, 0x01)               # Gamma curve selected
          write_command(0xB7, 0x06)
          write_command(0xE0, 0x0F, 0x31, 0x2B, 0x0C, 0x0E, 0x08, 0x4E, 0xF1, 0x37, 0x07, 0x10, 0x03, 0x0E, 0x09, 0x00)
          write_command(0XE1, 0x00, 0x0E, 0x14, 0x03, 0x11, 0x07, 0x31, 0xC1, 0x48, 0x08, 0x0F, 0x0C, 0x31, 0x36, 0x0F)
          write_command(0x11) # sleep_ms Exit
          time.sleep_ms(120)
          write_command(0x29)
          write_command(0x2C)
          bl.high()   # 拉背光
      def LCDdisplay(img):
          write_command(0x2C)
          write_image(img)
