  • 分辨人脸 OSError: Could not find the file
      # Face recognition with LBP descriptors.
      # See Timo Ahonen's "Face Recognition with Local Binary Patterns".
      # Before running the example:
      # 1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip
      # 2) Exract and copy the orl_faces directory to the SD card root.
      import sensor, time, image
      #SUB = "s1"
      NUM_SUBJECTS = 6 #图像库中不同人数,一共6人
      NUM_SUBJECTS_IMGS = 20 #每人有20张样本图片
      # 拍摄当前人脸。
      #d0为当前人脸的lbp特征
      img = None
      pmin = 999999
      num=0
      def min(pmin, a, s):
          global num
          if a<pmin:
              pmin=a
              num=s
          return pmin
          dist = 0
              img = image.Image("singtown/s%d/%d.pgm"%(s, i))
              #d1为第s文件夹中的第i张图片的lbp特征
          print(pmin)
      print(num) # num为当前最匹配的人的编号。
    • 你没有保存足够的图片。
