  • 我想用OpenMVH7来直接控制舵机转动
    • import sensor, image, time
      from pyb import Pin, Timer
      sensor.reset()  # 重置摄像头传感器
      sensor.set_pixformat(sensor.RGB565)  # 设置像素格式为RGB565,可以根据需要选择其他支持的格式
      sensor.set_framesize(sensor.QVGA)  # 设置帧大小为QVGA,可以根据需要选择其他支持的帧大小
      sensor.skip_frames(time = 2000)  # 等待摄像头稳定(2秒)
      red_threshold =(24, 100, -128, 127, 16, 127)
      yellow_threshold = (74, 100, -128, 127, 9, 127)
      green_threshold =(51, 100, -69, 127, 18, 127)
      red_color_code = 1
      yellow_color_code = 2
      green_color_code = 8
      servo1_pin = Pin('P7') # 初始化舵机1引脚P7
      servo2_pin = Pin('P8') # 初始化舵机2引脚P8
      timer1 = Timer(4, freq=50) # 设置定时器4的频率为50Hz
      timer2 = Timer(4, freq=50) # 设置定时器3的频率为50Hz
      servo1_pwm = timer1.channel(1, Timer.PWM, pin=servo1_pin, pulse_width=1500) # 设置舵机1的PWM信号输出通道
      servo2_pwm = timer2.channel(1, Timer.PWM, pin=servo2_pin, pulse_width=1500) # 设置舵机2的PWM信号输出通道
          blobs = img.find_blobs([red_threshold, yellow_threshold, green_threshold], area_threshold=100)
                  x = blob[0]
                  y = blob[1]
                  width = blob[2]
                  height = blob[3]
                  center_x = blob[5]
                  center_y = blob[6]
                  color_code = blob[8]
                  if color_code == red_color_code:
                      img.draw_string(x, y - 10, "red", color=(0xFF, 0x00, 0x00))
                      print("3")
                      servo1_pwm.pulse_width(1500 + 30 * 11.11) # 舵机1旋转30度
                      servo2_pwm.pulse_width(1500 + 30 * 11.11) # 舵机2旋转30度
                  elif color_code == yellow_color_code:
                      img.draw_string(x, y - 10, "yellow", color=(0xFF, 0x00, 0x00))
                      print("2")
                      servo1_pwm.pulse_width(1500) # 舵机1保持不动
                  elif color_code == green_color_code:
                      img.draw_string(x, y - 10, "green", color=(0xFF, 0x00, 0x00))
                      print("1")
                      servo1_pwm.pulse_width((1500 + 30 * 11.11)) # 舵机1旋转30度
                      servo2_pwm.pulse_width(1500 ) # 舵机2保持不动
                  img.draw_rectangle([x, y, width, height])
                  img.draw_cross(center_x, center_y)
      #,我接的是P7和P8引脚,代码如下,代码不报错,但是舵机也不转动,我的舵机是MG995,旋转180度的,请问是为什么
