添加显示器串口没输出没显示?
我在openmv4 h7加了显示器后,串口1显示器占用了吗?
img.draw_rectangle((12,128,240,55), color=(255, 255, 255), thickness=1,fill=False)
img.draw_rectangle((16,122,234,52), color=(255, 255, 255), thickness=1,fill=False)for threshold in thresholds: while True: j=0 for i,template in zip(data_templates,templates): r=img.find_template(template,threshold,step=4,search=SEARCH_EX) if r : img.draw_string(r[0], r[1], str(i), color=(255,255,255), scale=2) img.draw_rectangle(r, color=(0, 0, 0), fill=False) lcd.display(img)
运行程序显示器没显示?
串口1 和lcd扩展板引脚冲突。
