  • 代码也不报错,连接openmv运行就会自动终止运行,串行终端提示这个是怎么回事啊?
    • import sensor, image, time, os, tf, uos, gc, pyb, machine,math,tf
      uart = UART(3, 9600)
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)
      net = None
      labels = None
      ROI = (20,20,200,200)
      except Exception as e:
          print(e)
      def compare():
      	img1 = sensor.snapshot()
      	img1.draw_rectangle(ROI)
      	statistics = img1.get_statistics(roi = ROI)
      	img2 = sensor.snapshot()
      	img2.draw_rectangle(ROI)
      	statistics2 = img2.get_statistics(roi = ROI)
      	num1 = statistics.mode()
      	num2 = statistics.mode()
      	if(abs(num1-num2)>20):return 1
      	else:return 0
      def rubbish():
          pyb.delay(1000)
          print(clock.fps(), "fps")
          if (sum(predictions_list[i][1])/len(predictions_list[i][1]))>0.8:
              print(prediction_list[i][1])
              uart.write(predictions_list[i][0])
              rubbish()
      if(compare()==1):
      	rubbish()
      		if uart.any():
      			notice = uart.readline().decode()
      		if notice =='G':
      			rubbish()
    • 这个代码是哪里有问题吗?怎么运行不了也拍不了照片,传不了值?自动就停止运行了?跟arduino连接也没反应
      net = None
      labels = None
          print(e)
      def compare():
      	if(abs(num1-num2)>50):  return 1
          #print("1")return 0
      def rubbish():
          pyb.delay(1000)
          res = compare()
          if(res==1):
              print(OK)
              rubbish()
                  if uart.any():
                  if notice =='G':
                      rubbish()
    • 刚刚又改了一下代码,发现不报错了,但是串行终端没有输出数据,这个代码是哪里出问题了呀?
    • 错误太多,实在没法改。
