  • 为什么出现SyntaxError: invalid syntax呢
    • import time, sensor, image, math
      import sensor, image, math
      uart = UART(3, 9600)
      thresholds_red = [(30, 100, 15, 127, 15, 127)] # generic_red_thresholds
      thresholds_green = [(30, 100, -64, -8, -32, 32)] # generic_green_thresholds
      thresholds_blue = [(0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      int(cx), # up sample by 4 #数据1
      int(cy), # up sample by 4 #数据2
      int(cw), # up sample by 4 #数据1
      int(ch), # up sample by 4 #数据2
      int(cj), # up sample by 4 #数据1
      int(cz), # up sample by 4 #数据2
      img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens.
      print(code)
      qrcode2 = code.payload()
      cx = int(qrcode2[0:1])
      cy = int(qrcode2[1:2])
      cw = int(qrcode2[2:3])
      ch = int(qrcode2[4:5])
      cj = int(qrcode2[5:6])
      cz = int(qrcode2[6:7])
      print(cx)
      if cx == 1 :
      for blob in img.find_blobs(thresholds_red, pixels_threshold=200, area_threshold=200):   #未设置roi
          # These values depend on the blob not being circular - otherwise they will be shaky.
          if blob.elongation() > 0.5:
              img.draw_edges(blob.min_corners(), color=(255,0,0))
              img.draw_line(blob.major_axis_line(), color=(0,255,0))
              img.draw_line(blob.minor_axis_line(), color=(0,0,255))
          # These values are stable all the time.
          # Note - the blob rotation is unique to 0-180 only.
          img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)                #识别寻找红色色块
      uart.write('red')#发送完成信号
      print("red")
    • 缩进不对,if下面必须有缩进。
    • @kidswong999 解决了多谢
    • @kidswong999 while(True):
      print(code)
      print(cx)
      if cx == 1 :
      print("red")
      else if cx == 2 :
          for blob in img.find_blobs(thresholds_green, pixels_threshold=200, area_threshold=200):   #未设置roi
                  img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)                #识别寻找绿色色块
       uart.write('green')#发送完成信号
       print("green")
    • 62行和63行缩进也不对。
      print(code)
      print(cx)
      if cx == 1 :
                  print("red")
      else if cx == 2 :
                  print("green")
      else if cx == 3:
          for blob in img.find_blobs(thresholds_blue, pixels_threshold=200, area_threshold=200):   #未设置roi
                  img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)                #识别寻找蓝色色块
                  uart.write('blue')#发送完成信号
                  print("blue")
    • 我建议你先把python的语法学一遍,然后再写代码。这都是缩进这种基本问题。
    • @kidswong999 解决了谢谢,好久没用python了把elif写成else if了
