  • 例程18里代码最下面的sub_pixel_x,sub_pixel_y指的是速度吗?单位是多少?
    • # 通过mavlink实现光流
      # 该脚本使用MAVLink协议向ArduPilot / PixHawk控制器发送光流检测,以使用您的OpenMV Cam进行位置控制。
      # P4 = TXD
      import image, math, pyb, sensor, struct, time
      # 参数#################################################################
      uart_baudrate = 115200
      MAV_system_id = 1
      MAV_component_id = 0x54
      MAV_OPTICAL_FLOW_confidence_threshold = 0.1
      # 低于0.1左右(YMMV),结果只是噪音。
      # LED 控制
      led = pyb.LED(2) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
      led_state = 0
      def update_led():
          global led_state
          led_state = led_state + 1
          if led_state == 10:
              led.on()
          elif led_state >= 20:
              led.off()
              led_state = 0
      # 链接设置
      uart = pyb.UART(3, uart_baudrate, timeout_char = 1000)
      # 辅助工作
      packet_sequence = 0
      def checksum(data, extra): # https://github.com/mavlink/c_library_v1/blob/master/checksum.h
          output = 0xFFFF
          for i in range(len(data)):
              tmp = data[i] ^ (output & 0xFF)
              tmp = (tmp ^ (tmp << 4)) & 0xFF
              output = ((output >> 8) ^ (tmp << 8) ^ (tmp << 3) ^ (tmp >> 4)) & 0xFFFF
          tmp = extra ^ (output & 0xFF)
          return output
      MAV_OPTICAL_FLOW_message_id = 100
      MAV_OPTICAL_FLOW_id = 0 # unused
      MAV_OPTICAL_FLOW_extra_crc = 175
      # http://mavlink.org/messages/common#OPTICAL_FLOW
      # https://github.com/mavlink/c_library_v1/blob/master/common/mavlink_msg_optical_flow.h
      def send_optical_flow_packet(x, y, c):
          global packet_sequence
          temp = struct.pack("<qfffhhbb",
                             0,
                             0,
                             0,
                             0,
                             int(x),
                             int(y),
                             MAV_OPTICAL_FLOW_id,
                             int(c * 255))
          temp = struct.pack("<bbbbb26s",
                             26,
                             packet_sequence & 0xFF,
                             MAV_system_id,
                             MAV_component_id,
                             MAV_OPTICAL_FLOW_message_id,
                             temp)
          temp = struct.pack("<b31sh",
                             0xFE,
                             temp,
                             checksum(temp, MAV_OPTICAL_FLOW_extra_crc))
          packet_sequence += 1
          uart.write(temp)
      sensor.reset()                      # 复位并初始化传感器。
      sensor.set_framesize(sensor.B64X32) # 设置图像大小为64x32…(或64 x64)…
      sensor.skip_frames(time = 2000)     # 等待设置生效。
      clock = time.clock()                # 创建一个时钟对象来跟踪FPS帧率。
      # 从主帧缓冲区的RAM中取出以分配第二帧缓冲区。
      # 帧缓冲区中的RAM比MicroPython堆中的RAM多得多。
      # 但是,在执行此操作后,您的某些算法的RAM会少得多......
      # 所以,请注意现在摆脱RAM问题要容易得多。
      extra_fb = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.RGB565)
      extra_fb.replace(sensor.snapshot())
          clock.tick() # 追踪两个snapshots()之间经过的毫秒数.
          img = sensor.snapshot() # 拍一张照片,返回图像
          displacement = extra_fb.find_displacement(img)
          extra_fb.replace(img)
          # 没有滤波,偏移结果是嘈杂的,所以我们降低了一些精度。
          sub_pixel_x = int(-displacement.x_translation() * 35)
          sub_pixel_y = int(displacement.y_translation() * 53)
          if(displacement.response() > MAV_OPTICAL_FLOW_confidence_threshold):
              send_optical_flow_packet(sub_pixel_x, sub_pixel_y, displacement.response())
              print("{0:+f}x {1:+f}y {2} {3} FPS".format(sub_pixel_x, sub_pixel_y,
                    displacement.response(),
                    clock.fps()))
    • 这个代码我不知道,你可以参考这里:https://forums.openmv.io/t/python-script-to-output-mavlink/217/30
    • @kidswong999 好的🌹
