  • 请问这个怎么解决?RuntimeError: Frame capture has timed out.
    • import sensor, image, time
      uart = UART(3,19200)
      A=uart.read()==b'0x31'
      B=uart.read()==b'0x32'
          img=sensor.snapshot()
          while(A):
          #clock.tick()
          #img = sensor.snapshot()
              for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2):
                  img.draw_circle(c.x(), c.y(), c.r(), color = (0, 255, 0))
                  if(c.x()>90):
                      uart.write("d\r")
                      if(c.x()<70):
                          uart.write("c\r")
                      else:uart.write("e\r")
                  if(c.y()>70):
                      uart.write("a\r")
                      if(c.x()<50):
                          uart.write("b\r")
                  time.sleep(1)
          while(B):
          #clock.tick()
              thresholds1 = [(30,100,15,127,15,127),(0, 60, -8, 69, -125, -3),(25, 53, -74, -23, 28, 58)]
              for blob in img.find_blobs(thresholds1, pixels_threshold=500, area_threshold=2000):
                  uart.write(blob.code())
      我开始运行后,他软件内显示到的图像活动几秒后就不动了,然后自动结束进程,请问这怎么解决?
    • 运行hello world,如果还有问题,寄回维修。
