教程的测距代码,使用了ov5640,framesize改为sensor.FHD,报错memory erros,为何?
# Measure the distance # # This example shows off how to measure the distance through the size in imgage # This example in particular looks for yellow pingpong ball. import sensor, image, time # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... yellow_threshold = (2, 85, -128, 127, 18, 64) # You may need to tweak the above settings for tracking green things... # Select an area in the Framebuffer to copy the color settings. sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.FHD) #【ov5640】 sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. K=5000#the value should be measured while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([yellow_threshold], x_stride=2, y_stride=1) if len(blobs) == 1: # Draw a rect around the blob. b = blobs[0] img.draw_rectangle(b[0:4]) # rect img.draw_cross(b[5], b[6]) # cx, cy Lm = (b[2]+b[3])/2 length = K/Lm print(length) #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while # connected to your computer. The FPS should increase once disconnected.
以为是内容的问题,插入了sd新卡,仍旧报错。
请大佬不吝指点。谢谢
ide 3.0.3,windows7 ,openmv4 H7
硬件为OpenMV4 H7 PLUS
我是用OpenMV4 H7 Plus,固件4.4.2,没有出现错误。
@kidswong999
感谢回复。
没有改动程序。没有错误。不知道是不是以后还会抽筋。
