  • 获取特征点的中心坐标报错
    • import sensor, time, image
      # 重置传感器
      # 传感器设置
      sensor.set_auto_gain(False, value=100)
      FILE_NAME = "desc"
      img = image.Image("/binary.pgm", copy_to_fb=True)
      # 注意:请参阅文档查看其他参数
      # 注:默认情况下,find_keypoints返回从图像中提取的多尺度关键点。
      kpts = img.find_keypoints(max_keypoints=150, threshold=10, scale_factor=1.2)
      if (kpts == None):
          raise(Exception("Couldn't find any keypoints!"))
      image.save_descriptor(kpts, "/%s.orb"%(FILE_NAME))
      img.save("/%s.pgm"%(FILE_NAME))
      img.draw_keypoints(kpts)
      sensor.snapshot()
      time.sleep_ms(1000)
      #raise(Exception("Done! Please reset the camera"))
      image.match_descriptor
      print(image.kptmatch.cx())
    • https://book.openmv.cc/example/09-Feature-Detection/keypoints.html
      看这个程序。你的代码都不对。
