  • 我想把深度学习检测到的结果通过WiFi模块发送到电脑上
    • import sensor, image, time, os, tf, uos, gc, network, usocket, sys, json
      KEY  ='1234567890'    # Network key (must be 10 chars)
      HOST = ''           # Use first available interface
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      net = None
      labels = None
      except Exception as e:
          print(e)
      # Init wlan module in AP mode.
      # You can block waiting for client to connect
      def response(s):
          client, addr = s.accept()
          # set client socket timeout to 2s
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Should parse client request here
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Content-Type: application/json\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          # Start streaming images
          # NOTE: Disable IDE preview to increase streaming FPS.
              #print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect())
                  #print("%s = %f" % (predictions_list[i][0], predictions_list[i][1]))
                  a=obj.output()[0]
                  b=obj.output()[1]
                  c=obj.output()[2]
                  d=obj.output()[3]
                  f=obj.output()[4]
                  g=obj.output()[5]
                  if a>0.95:
                      h=1
                      print(h)
          client.send(json.dumps(h))
          client.close()
          # Create server socket
              # Bind and listen
              s.bind([HOST, PORT])
              s.listen(5)
              # Set server socket timeout
              # NOTE: Due to a WINC FW bug, the server socket must be closed and reopened if
              # the client disconnects. Use a timeout here to close and re-create the socket.
              s.settimeout(3)
              response(s)
          except OSError as e:
              s.close()
              print("socket error: ", e)
              #sys.print_exception(e)
    • 在73行:img = sensor.snapshot()下面,添加一句h=0
      我加了那个可是现在的问题就是那个196.168.1.1都进不去
    • @kidswong999 我感觉我这个模型训练和这个WiFi传输没有加好,还有一个问题就是我这个程序运行起来没几分钟摄像头就不动了,就像卡住了一样,但是不报错
    • 你的程序是,每次访问才采集和运行一次。
    • @kidswong999 那我需要怎么改才能像那个传输小球坐标一样一直传呢
    • @k5r1 传输小球坐标,也是访问一次识别一次。你可以写一个js,每秒循环访问。
    • @kidswong999 不太懂应该怎么写啊 关键是现在我这个代码就是那个网站都进不去水为什么呢
