  • openmv执行人脸识别的官方例程代码时,出现OSError:Assertion failed,请问一下是什么问题?
      # Untitled - By: MK - 周日 2月 12 2023
      # Face recognition with LBP descriptors.
      # See Timo Ahonen's "Face Recognition with Local Binary Patterns".
      # Before running the example:
      # 1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip
      # 2) Exract and copy the orl_faces directory to the SD card root.
      #SUB = "s1"
      NUM_SUBJECTS = 4 #图像库中不同人数,一共4人
      NUM_SUBJECTS_IMGS = 10 #每人有10张样本图片
      # 拍摄当前人脸。
      #d0为当前人脸的lbp特征
      img = None
      pmin = 999999
      num=0
      def min(pmin, a, s):
          global num
          if a<pmin:
              pmin=a
              num=s
          return pmin
          dist = 0
              img = image.Image("singtown/s%d/%d.pgm"%(s, i))
              #d1为第s文件夹中的第i张图片的lbp特征
              dist += image.match_descriptor(d0, d1)#计算d0 d1即样本图像与被检测人脸的特征差异度
          pmin = min(pmin, dist/NUM_SUBJECTS_IMGS, s)#特征差异度越小,被检测人脸与此样本更相似更匹配
          print(pmin)
      print(num) # num为当前最匹配的人的编号
    • 检查一下目录,估计是图片不够。
