  • 垃圾分类openmv神经网络模型,openmv怎么准确识别垃圾的位置,让机械臂抓取呢?
    • Edge Impulse - OpenMV Image Classification Example
      import sensor, image, time, os, tf, uos, gc, pyb
      from pyb import UART,LED
      sensor.set_windowing((128, 128)) # Set 240x240 window.
      LED(1).on()
      LED(2).on()
      LED(3).on()
      uart = UART(3,9600,timeout_char=1000)
      net = None
      labels = None
      except Exception as e:
      print(e)
      obj = net.classify(img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5)
      程序运行都是摄像头整幅画面
    • 用FOMO模型,可以识别到位置
      https://singtown.com/learn/50918/
