  • 串行终端,只显示最高得分
    • # Edge Impulse - OpenMV Image Classification Example
             import sensor, image, time, os, tf, uos, gc
             net = None
             labels = None
             except Exception as e:
                 print(e)
                 print(clock.fps(), "fps")
    • 添加什么代码,让其只在川行输出最高分?
