  • attributeerror:'tf_modle' object has no attribute 'detect'
    • # Edge Impulse - OpenMV Object Detection Example
      import sensor, image, time, os, tf, math, uos, gc
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # detect() returns all objects found in the image (splitted out per class already)
          # we skip class index 0, as that is the background, and then draw circles of the center
          # of our objects
          for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])):
              if (i == 0): continue # background class
              if (len(detection_list) == 0): continue # no detections for this class?
              for d in detection_list:
                  [x, y, w, h] = d.rect()
                  print('x %d\ty %d' % (center_x, center_y))
                  img.draw_circle((center_x, center_y, 12), color=colors[i], thickness=2)
    • 请问下 是什么原因出现的错误? 错误发生在第46行
    • 升级到最新固件。
