  • 请问一下追踪小车car.py里,run(left_speed, right_speed)中,相对应的电机角速度是多少?
    • 请问一下追踪小车car.py里,run(left_speed, right_speed)中,相对应的电机角速度是多少?比如car.run(10,20).对电机这一块不是很了解
      from pyb import Pin, Timer
      inverse_left=False  #change it to True to inverse left wheel
      ain1 =  Pin('P0', Pin.OUT_PP)
      ain2 =  Pin('P1', Pin.OUT_PP)
      bin1 =  Pin('P2', Pin.OUT_PP)
      bin2 =  Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
          if inverse_left==True:
              left_speed=(-left_speed)
          if inverse_right==True:
              right_speed=(-right_speed)
          if left_speed < 0:
              ain1.low()
              ain2.high()
              ain1.high()
              ain2.low()
          ch1.pulse_width_percent(int(abs(left_speed)))
          if right_speed < 0:
              bin1.low()
              bin2.high()
              bin1.high()
              bin2.low()
          ch2.pulse_width_percent(int(abs(right_speed)))
    • pwm是10%和20%
      不同的电机不一样,电机没有把角速度的值写出来。
    • 就是官方的n20电机,那对应的转速能知道不?
    • @kidswong999 就是官方的n20电机,那对应的转速能知道不?
    • @3sbx 厂家没有给我这个参数。
