  • 追踪小车里,如何让小车固定一个角度寻找目标,比如90度,而不是转圈?
    • 追踪小车里,如何让小车固定一个角度寻找目标,而不是转圈?
      # Blob Detection Example
      # This example shows off how to use the find_blobs function to find color
      # blobs in the image. This example in particular looks for dark green objects.
      import car
      led = pyb.LED(3)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      sensor.skip_frames(50) # Let new settings take affect.
      green_threshold   = (22, 85, -66, -28, -29, 65)
      #green_threshold   = (0, 16, 12, 33, -1, 24)
      size_threshold = 2000
      x_pid = PID(p=0.5, i=1, imax=0)
      h_pid = PID(p=0.03, i=0.1, imax=0)
              max_blob = find_max(blobs)
              x_error = max_blob[5]-img.width()/2
              h_error = max_blob[2]*max_blob[3]-size_threshold
              print("x error: ", x_error)
              for b in blobs:
              img.draw_rectangle(max_blob[0:4]) # rect
              img.draw_cross(max_blob[5], max_blob[6]) # cx, cya
              x_output=x_pid.get_pid(x_error,1)
              h_output=h_pid.get_pid(h_error,1)
              print("h_output",h_output)
              car.run(-h_output-x_output,-h_output+x_output)
              car.run(10,0)
              pyb.delay(1500)
              car.run(-10,0)
              pyb.delay(1500)
    • 你不能控制角度,因为没有角度传感器。
      你只能能控制它的时间,比如向左转了1秒没找到就回头转1秒。
