  • 我在uart.write(c[0].x,c[1].x等等点)时会报错,让我不要加[],
    • 是这样的,但我在uart.write(c[0].x,c[1].x等等点)时会报错,让我不要加[],这怎样解决
      像这样
    • import sensor, image, time, pyb
          # Circle objects have four values: x, y, r (radius), and magnitude. The
          # magnitude is the strength of the detection of the circle. Higher is
          # better...
          # `threshold` controls how many circles are found. Increase its value
          # to decrease the number of circles detected...
          # `x_margin`, `y_margin`, and `r_margin` control the merging of similar
          # circles in the x, y, and r (radius) directions.
          # r_min, r_max, and r_step control what radiuses of circles are tested.
          # Shrinking the number of tested circle radiuses yields a big performance boost.
          for circles in img.find_circles(threshold = 2000, x_margin = 10, y_margin = 10, r_margin = 10,
                  r_min = 2, r_max = 100, r_step = 2):
              c0=circles[0].x()
              print(c0)
      最后就会显示AttributeError: 'int' object has no attribute 'x'
    • 正确的代码:
          circles = img.find_circles(threshold = 2000, x_margin = 10, y_margin = 10, r_margin = 10,
          for c in circles:
          if len(circles) > 0:
              c0=circles[0].x()
              print(c0)
