  • 识别色块跟tof光学测距拓展板联合使用后读取距离的问题
    • 通过看教程将两个示例合并使用,但是想实现识别到色块然后才读取距离,然后串口再将距离发送给stm32,大佬,麻烦帮忙修改一下代码,惯我一次,我在咱家已经买了两个摄像头跟一大堆元件了。
      threshold_index = 0 # 0 for red, 1 for green, 2 for blue
                    (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
      from machine import I2C
      from vl53l1x import VL53L1X
      i2c = I2C(2)
      distance = VL53L1X(i2c)
      # camera resolution. "merge=True" merges all overlapping blobs in the image.
          for blob in img.find_blobs([thresholds[threshold_index]],roi=(150,90,80,80), pixels_threshold=200, area_threshold=200, merge=True):
              # These values depend on the blob not being circular - otherwise they will be shaky.
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255,0,0))
                  img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  img.draw_line(blob.minor_axis_line(), color=(0,0,255))
              # These values are stable all the time.
              # Note - the blob rotation is unique to 0-180 only.
              img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)
          print("range: mm ", distance.read())
          time.sleep_ms(50)
    • 此回复已被删除!
      大佬,惯我一次吧,真的在咱家买了好多东西
    • 大概就是这个意思:
          blobs = img.find_blobs()
              d = distance.read()
              uart.write(str(d))
          for b in blobs:
              xxx
