我在使用bytearray([0x2C,0x12,0x5B]) 函数的时候 想在里面插入元素 报错的问题
import time, sensor, image,pyb from image import SEARCH_EX, SEARCH_DS from pyb import UART import ustruct from pyb import LED one=LED(1) #从imgae模块引入SEARCH_EX和SEARCH_DS。使用from import仅仅引入SEARCH_EX, #SEARCH_DS两个需要的部分,而不把image模块全部引入。 clock = time.clock() # Reset sensor sensor.reset() # Set sensor settings sensor.set_contrast(1) #设置对比度 sensor.set_gainceiling(16) #设定增益曲线 sensor.set_framesize(sensor.QQVGA) sensor.set_pixformat(sensor.GRAYSCALE) #串口3定义 uart1 = UART(3,115200) #定义串口3变量 uart1.init(115200, bits=8, parity=None, stop=1) # init with given parameters def sending_data(cx,cy): global uart1; #frame=[0x2C,18,cx%0xff,int(cx/0xff),cy%0xff,int(cy/0xff),0x5B]; #data = bytearray(frame) datasum=ustruct.pack("<bbhhhhb", #格式为俩个字符俩个短整型(2字节) 0x2C, #帧头1 0x12, #帧头2 int(cx), # up sample by 4 #数据1 int(cy), # up sample by 4 #数据2 0x5B) uart1.write(datasum); #必须要传入一个字节数组 #初始模板 templatedemo = ["/1.pgm", "/2.pgm", "/3.pgm", "/4.pgm","/5.pgm", "/6.pgm", "/7.pgm", "/8.pgm"] ##分类模板 templates = (["/3.pgm", "/32.pgm", "/33.pgm", "/34.pgm","/35.pgm", "/36.pgm"], ["/4.pgm", "/42.pgm", "/43.pgm", "/44.pgm","/45.pgm", "/46.pgm"], ["/5.pgm", "/52.pgm", "/53.pgm", "/54.pgm","/55.pgm", "/56.pgm"], ["/6.pgm", "/62.pgm", "/63.pgm", "/64.pgm","/65.pgm", "/66.pgm"], ["/7.pgm", "/72.pgm", "/73.pgm","/74.pgm","/75.pgm", "/76.pgm","/701.pgm","/702.pgm","/703.pgm","/704.pgm","/705.pgm","/706.pgm"], ["/8.pgm","/82.pgm", "/83.pgm", "/84.pgm","/85.pgm", "/86.pgm","/801.pgm","/802.pgm","/803.pgm","/804.pgm","/805.pgm","/806.pgm"]) #8\ imgarray=[0,0,0,0,0,0,0,0] imgarrays=[0,0,0,0,0,0,0,0,0,0,0,0] first=0 def get_first(img):#病房号识别输入 返回一到八 判断初始模板 #print("get_first") global imgarray r = img.find_template(imgarray[0], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 1 r = img.find_template(imgarray[1], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 2 r = img.find_template(imgarray[2], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 3 r = img.find_template(imgarray[3], 0.7 ,step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 4 r = img.find_template(imgarray[4], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 5 r = img.find_template(imgarray[5], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 6 r = img.find_template(imgarray[6], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 7 r = img.find_template(imgarray[7], 0.7, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 8 return 0 '''def isget(num):#判断是否输入成功 if num is not 0: for i in range (num): one.on() print(num) #使用时删除 给自己看的 time.sleep_ms(100) one.off() time.sleep_ms(100) cx = num''' def getimgs(imgarr): i=0 #print("getimgs") for t in imgarr: imgarrays[i]=image.Image((t)) #print(imgarrays[i]) i+=1 return imgarrays def match_img(photos,img):#模板匹配 isget=0 #print("match_img") for t in photos: #print(t) r = img.find_template(t, 0.50, step=4, search=SEARCH_EX)#不能将int转换为type if r: img.draw_rectangle(r) isget=1 break else: pass if isget==1: sending_data(0x37,0x12) #55 isget=0 else: sending_data(0x73,0x21) #115 def loadimg(): #导入正常图片八张 #print("loading") i=0 for t in templatedemo: imgarray[i]=image.Image(str(t)) i+=1 return imgarray imgarray=loadimg() #加载初始八张图 FH = bytearray([0x2C,0x12,0x5B]) while (True): clock.tick() img = sensor.snapshot() if imgarrays[0]!=0: match_img(imgarrays,img)#比对当前帧图片与加载进来的模板库匹配 else: if first==0: #获取初始图片标志位 first=get_first(img) #first用于判断当前是那张图片 if first is not 0: for i in range (first): one.on() print(first) #使用时删除 给自己看的 time.sleep_ms(100) one.off() time.sleep_ms(100) cx = first#亮灯提醒是否识别到初始图片 bytearray.insert(2,cx) print(FH) uart1.write(FH) elif first==1: sending_data(0x10) # 确定是1 elif first==2: sending_data(0x20) #确定是2 elif imgarrays[0]==0: #确定图片缓冲区第一次是空 imgarrays=getimgs(templates[first-3])#load photo 加载图片 执行一次 else:#之后程序只会在这里执行 pass print("FPS:",clock.fps())#帧率显示
怎么解决 我查了网上资料 bytearray([0x2C,0x12,0x5B]) 我用了 bytearray.insert(2,cx) 却给报错
@bxr1
版本
报错提示很清楚了, bytearray不能insert。bytearray不是列表,是不能插入的。
解决办法:只在uart.write()的时候生成bytearray。其他情况下用list。
@kidswong999 我之前写了一个 list=[0x2C,0x12,cx,0x5B] 然后再添加进list 再把list放入bytearray 变成bytearray(list)
然后我打印bytearray 加入的东西是不在里面的
@bxr1 复制多了 那个cx 是我添加的
@bxr1 在 我在使用bytearray([0x2C,0x12,0x5B]) 函数的时候 想在里面插入元素 报错的问题 中说:
然后我打印bytearray 加入的东西是不在里面的发一个新帖子,附上全部代码。
最好是可以马上复现错误的,否则查起来太费劲,你的无关代码太多。
