  • 请问我h7进行模板匹配出现 Frame capture has timed out,怎么解决?
    • # Template Matching Example - Normalized Cross Correlation (NCC)
      # image patches to parts of an image... expect for extremely controlled enviorments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will reamin to show
      import time, sensor, image
      # Reset sensor
      # Set sensor settings
      # Load template.
      template = image.Image("/2.pgm")
      # Run template matching
          r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r)
    • 这个是摄像头拍照出的错误。
      用的什么硬件?什么固件?什么摄像头模块?hello world是否正常?
