生成出来的程序运行时出错误OSError【Errno 2】ENOENT应该怎么解决?
Edge Impulse - OpenMV Image Classification Example
sensor.skip_frames(time=2000) # Let the camera adjust.net = "trained.tflite"
labels = [line.rstrip('\n') for line in open("labels.txt")]clock = time.clock()
clock.tick()img = sensor.snapshot() # default settings just do one detection... change them to search the image... for obj in tf.classify(net, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5): print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect()) img.draw_rectangle(obj.rect()) # This combines the labels and confidence values into a list of tuples predictions_list = list(zip(labels, obj.output())) for i in range(len(predictions_list)): print("%s = %f" % (predictions_list[i][0], predictions_list[i][1])) print(clock.fps(), "fps")
https://singtown.com/learn/50872/
按照视频步骤操作,把文件复制到OpenMV弹出来的U盘里。
@kidswong999 我就是按照它的步骤放在u盘里面
@3eug 格式化,然后重新复制。等红灯灭了,重启OpenMV,然后运行代码。
@kidswong999 这次没出之前的错误告诉我堆栈内存不足这个应该怎么解决
@3eug 新的问题单独发帖子,先搜搜别人的问题。
@kidswong999 好的十分感谢
