  • 为什么这个程序他只能识别出红色?
    • import sensor, image, time, math
      # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      # The below thresholds track in general red/green things. You may wish to tune them...
      thresholds = [(13, 30, 1, 45, -24, 47), # generic_red_thresholds
                   (23, 55, -44, -24, -2, 39), # generic_green_thresholds
                   (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      # You may pass up to 16 thresholds above. However, it's not really possible to segment any
      # scene with 16 thresholds before color thresholds start to overlap heavily.
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
         red=[]
         green=[]
         blue=[]
         shit=[]
         order=[]
         for r in img.find_rects(threshold = 10000):
             area = (r.rect())
             #area为识别到的矩形的区域
             statistics = img.get_statistics(roi=area)#像素颜色统计i=0,j=0,n=0
             #print(statistics)
             #(0,100,0,120,0,120)是红色的阈值
             #l_mode(),a_mode(),b_mode()是L通道,A通道,B通道的众数。
             if 8<statistics.l_mode()<20 and 10<statistics.a_mode()<45 and 0<statistics.b_mode()<36:
                img.draw_rectangle(area, color = (255, 0, 0))#识别到的红色矩形用红色的矩形框出来
                if 1.8<(r.w()/r.h())<2.2:
                     red.append(r.y())
                elif (0.8<(r.w()/r.h())<1.2):
                     red.append(r.y())
                     red.append(r.y()-r.h()/2)
                 elif (0.5<=(r.w()/r.h())<=0.79):
                     red.append(r.y()-2*r.h()/3)
                     red.append(r.y()-r.h()/3)
                     red.append(r.y())
             if 30<statistics.l_mode()<51 and -45<statistics.a_mode()<-21 and 9<statistics.b_mode()<46:
                 if 1.8<=r.w()/r.h()<=2.2:
                     green.append(r.y())
                 elif(0.8<=r.w()/r.h()<=1.2):
                     green.append(r.y())
                     green.append(r.y()-r.h()/2)
                 elif(0.5<=r.w()/r.h()<0.8):
                     green.append(r.y())
                     green.append(r.y()-2*r.h()/3)
                     green.append(r.y()-r.h()/3)
             if 44<statistics.l_mode()<55 and -30<statistics.a_mode()<-5 and -24<statistics.b_mode()<0:
                     blue.append(r.y())
                     blue.append(r.y()-r.h()/2)
                     blue.append(r.y())
                     blue.append(r.y())
                     blue.append(r.y()-2*r.h()/3)
                     blue.append(r.y()-h/3)
         l1=len(red)
         l2=len(green)
         l3=len(blue)
         i=0
         while i<l1:
            shit.append(red[i])
            order.append(3)
            i=i+1
         while i<(l1+l2):
             shit.append(green[i-l1])
             order.append(1)
             i=i+1
         while i<(l1+l2+l3):
             shit.append(blue[i-l1-l2])
             order.append(2)
             i=i+1
         i=0
         n=0
         print('red')
         print(red)
         while len(shit)<6:
             shit.append(0)
             order.append(0)
             n=n+1
          for i in range(5):
             for j in range(5-i):
                 if shit[j]>shit[j+1]:
                     shit[j],shit[j+1]=shit[j+1],shit[j]
                     order[j],order[j+1]=order[j+1],order[j]
         print(order)
    • 这段代码大致就是六个色块,从上往下排列,一个色块有一种颜色(总共三种),一个数字代表一个色块,然后你按顺序输出对应的数字,但是他最后只能识别到红色,(我觉得我阈值设置的没有问题
    • 在第42行,62行,80行,都加入print,你就能看出来到底是什么。逻辑问题自己慢慢就能挑出来。
