  • openmv的帧率太低了几乎是2帧每秒,如何提高帧率!
    • # Blob Detection Example
      # This example shows off how to use the find_blobs function to find color
      # blobs in the image. This example in particular looks for dark green objects.
      #sensor.set_windowing((100, 100))
      green_threshold   = (54, 95, -4, 30, 22, 70)
      size_threshold = 1500
      blue_led = pyb.LED(3)
      green_led = pyb.LED(2)
      red_led = pyb.LED(1)
      uart = UART(3, 9600)
      sensor.set_auto_exposure(True, exposure_us=5000) # make smaller to go faster
          #FZ = bytearray([0x55,0x55,0x12,0x03,0x03,0xd0,0x07,0x01,0xa1,0x02,0x02,0x04,0x05,0x03,0x6c,0x06])
          #FZ1 = bytearray([0x55,0x55,0x14,0x03,0x05,0xd0,0x07,0x01,0x05,0x09,0x02,0x4c,0x05,0x03,0xe9,0x02,0x04,0xc1,0x07,0x05,0x24,0x02])
          #FZ1 = bytearray([0x55,0x55,0x08,0x03,0x01,0xd0,0x07,0x01,0x05,0x09])
          #uart.write(FZ1)
          #FZ2 = bytearray([0x55,0x55,0x08,0x03,0x02,0xd0,0x07,0x02,0x4c,0x05])
          #uart.write(FZ2)
          #time.sleep_ms(1000)
          #FZ3 = bytearray([0x55,0x55,0x08,0x03,0x03,0xd0,0x07,0x03,0xe9,0x02])
          #uart.write(FZ3)
          #FZ4 = bytearray([0x55,0x55,0x08,0x03,0x04,0xd0,0x07,0x04,0xc1,0x07])
          #uart.write(FZ)
          time.sleep_ms(1000)
          xiangshu=0
              max_blob = find_max(blobs)
              max_blob1=find_max1(blobs)
              xiangshu = max_blob.blob[4]
              img.draw_rectangle(max_blob[0:4]) # rect
              img.draw_cross(max_blob[5], max_blob[6]) # cx, cy
              if xiangshu > size_threshold:
                          #FZ = bytearray([0x55,0x55,0x05,0x06,0x64,0x01,0x00])
                          #art.write(FZ)
                          red_led.on()
                          time.sleep_ms(150)#延时150ms
                          red_led.off()
                          blue_led.on()
                          time.sleep_ms(150)     #延时150ms
                          blue_led.off()
              green_led.on()
              green_led.off()
    • 把time.sleep都删掉。延时了当然低。
