  • 串口发送失败
      Single Color RGB565 Blob Tracking Example
      This example shows off single color RGB565 tracking using the OpenMV Cam.
      import sensor, image, time,json
      threshold_index = 0 # 0 for red, 1 for green, 2 for blue
      Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      The below thresholds track in general red/green/blue things. You may wish to tune them...
      thresholds = [(0, 98, 92, 17, -128, 127)] # generic_red_thresholds
      #(30, 100, -64, -8, -32, 32), # generic_green_thresholds
      # (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
      Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are
      returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the
      camera resolution. "merge=True" merges all overlapping blobs in the image.
      uart = UART(3, 19200)
      uart.init(19200, bits=8, parity=None, stop=1)
      for blob in img.find_blobs([thresholds[0]], pixels_threshold=200, area_threshold=200, merge=True):
      print(blob.cx(),blob.cy())
      uart.write(blob.cx(),blob.cy())
      time.sleep(1000)
      这是代码
    • 解决了,是因为固件没有刷新
