  • 请问我的OPENMV_AP为什么启动不了?我的接线是对的,为什么例子里边的OPENMV_AP也启动不了?
    • # Untitled - By: Administrator - 周二 12月 8 2020
      # AprilTags Example
      # This example shows the power of the OpenMV Cam to detect April Tags
      # on the OpenMV Cam M7. The M4 versions cannot detect April Tags.
      import sensor, image, time, math,network, usocket, sys, json
      KEY  ='1234567890'    # Network key (must be 10 chars)
      HOST = ''           # Use first available interface
      green_threshold   = (   0,   80,  -70,   -10,   -0,   30)
      sensor.set_framesize(sensor.QQVGA) # we run out of memory if the resolution is much bigger...
      sensor.skip_frames(30)
      sensor.set_auto_gain(False)  # must turn this off to prevent image washout...
      sensor.set_auto_whitebal(False)  # must turn this off to prevent image washout...
      # 注意!与find_qrcodes不同,find_apriltags 不需要软件矫正畸变就可以工作。
      # 注意,输出的姿态的单位是弧度,可以转换成角度,但是位置的单位是和你的大小有关,需要等比例换算
      # f_x 是x的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/3.984*656,这个值是用毫米为单位的焦距除以x方向的感光元件的长度,乘以x方向的感光元件的像素(OV7725)
      # f_y 是y的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/2.952*488,这个值是用毫米为单位的焦距除以y方向的感光元件的长度,乘以y方向的感光元件的像素(OV7725)
      # c_x 是图像的x中心位置
      # c_y 是图像的y中心位置
      # Init wlan module in AP mode.
      wlan = network.WINC()
      wlan.connect(SSID, key=KEY, security=wlan.WPA_PSK)
      #wlan.start_ap(SSID, key=KEY, security=wlan.WEP, channel=2)
      # You can block waiting for client to connect
      def response(s):
          client, addr = s.accept()
          # set client socket timeout to 2s
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Should parse client request here
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Content-Type: application/json\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          client.send(dx)
          client.close()
      f_x = (2.8 / 3.984) * 160 # 默认值
      f_y = (2.8 / 2.952) * 120 # 默认值
      c_x = 160 * 0.5 # 默认值(image.w * 0.5)
      c_y = 120 * 0.5 # 默认值(image.h * 0.5)
      def degrees(radians):
          return (180 * radians) / math.pi
             # Bind and listen
             s.bind([HOST, PORT])
             s.listen(5)
      # Set server socket timeout
              # NOTE: Due to a WINC FW bug, the server socket must be closed and reopened if
              # the client disconnects. Use a timeout here to close and re-create the socket.
             s.settimeout(3)
             response(s)
          except OSError as e:
              s.close()
              print("socket error: ", e)
              #sys.print_exception(e)
          for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11
              img.draw_rectangle(tag.rect(), color = (255, 0, 0))
              img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0))
              d=dx=dy=dz=1.0
              Tx=abs(tag.x_translation())
              Ty=abs(tag.y_translation())
              Tz=abs(tag.z_translation())
              dx=27.33*Tx
              dy=27.33*Ty
              dz=27.33*Tz
              print_args = (dx, dy, dz, \
                  degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation()))
              # 位置的单位是未知的,旋转的单位是角度
              print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args)
              import requests
              dx = requests.get('192.168.1.1:8080')
              dy = requests.get('192.168.1.1:8080')
              dz = requests.get('192.168.1.1:8080')
    • 提示很清楚了,你用的是STATION模式,不是AP模式。
      按照视频步骤操作:
      https://singtown.com/learn/50005/
