  • uart = UART(1,115200)为什么不可以使用啊,我想不用uart3的引脚用uart1的引脚,求大佬解答,?
    • import sensor, image, time
      yellow_threshold   = ( 46,  100,  -68,   72,   58,   92)
              #print('sum : %d'% len(blobs))
              data=[]
              for b in blobs:
                  img.draw_rectangle(b.rect()) # rect
                  img.draw_cross(b.cx(), b.cy()) # cx, cy
                  data.append((b.cx(),b.cy()))
              #{(1,22),(-3,33),(22222,0),(9999,12),(0,0)}
              data_out = json.dumps(set(data))
              uart.write(data_out +'\n')
              print('you send:',data_out)
              print("not found!")
    • 报错是:uart(1) doesn't ecist
    • 你使用的是什么硬件和什么固件?
    • 已解决,谢谢你的回复
