openmv串口和测距模块
import sensor, image, time from machine import I2C from vl53l1x import VL53L1X from pyb import LED from pyb import UART, Timer from pyb import Servo from pid import PID uart = UART(1,115200) i2c = I2C(2) distance = VL53L1X(i2c) test_state = 1 L = 0 chang = 0 #cir.r = 300 pan_pid=PID(p=0.05, i=0.01, d=0, imax=90) #在线调试PID tilt_pid=PID(p=0.05, i=0.012,d=0, imax=90) #pan_pid=PID(p=0.06, i=0.1, d=0.02, imax=100) #脱机运行PID #tilt_pid=PID(P=0.05, i=0.05, d=0, imax=90) ''' rect_threshold=(20, 47, 29, 70, 12, 58) #(24, 45, 32, 70, 12, 58) circle_threshold=(61, 23, 31, 81, 5, 59) ''' all_thresholds = [(30, 100, 15, 127, 15, 127), # _red_thresholds (30, 100, -64, -8, -32, 32), # _green_thresholds (0, 15, 0, 40, -80, -20)] # _blue_thresholds sensor.reset() sensor.set_pixformat(sensor.RGB565) # 灰度更快(160x120 max on OpenMV-M7) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) clock = time.clock() def uart_singal(): buff = 0 buff = uart.any() if buff > 0: _data_receive(readchar()) else: pass def _data_receive(data): if data == 65: test_state = 1 elif data == 66: test_state = 2 else: print('error!!!') def test1_2(): for r in img.find_rects(threshold = 20000): area_rectangle = (r.rect()) #是为了在检测矩形的基础上检测有颜色的矩形 for blob in img.find_blobs(all_thresholds, pixels_threshold=100, area_threshold=100, merge=True, margin=10,roi = area_rectangle): img.draw_rectangle(area_rectangle, color = (0, 255, 0)) LED(1).toggle() for c in img.find_circles(threshold = 2200): area_circle = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r())#是为了在检测有圆的基础上检测有颜色的圆 draw_cir = (c.x(), c.y(), c.r())#画圆的轮廓 for blob in img.find_blobs(all_thresholds, pixels_threshold=100, area_threshold=100, merge=True, margin=10, roi = area_circle): img.draw_circle(draw_cir, thickness=1, color = (0,255,0), fill=False) LED(3).toggle() L = distance.read()-50 print(L) chang = L uart.write(chang) def test3_4(): pass def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3]>max_size: max_blob=blob max_size=blob[2]*blob[3] return max_blob while(True): clock.tick() img = sensor.snapshot() if(test_state == 1): test1_2() elif(test_state == 2): test3_4() else: pass uart_singal()
我想问问为啥我用串口1发送openmv测距模块得到的距离值他会报错,测距模块不是占用的串口3吗?
L是int,uart.write只能发送字节串(字符串)。
uart.write(str(L))#转为字符串
