  • 对于Machine神经网络区域中心识别代码
    • 0_1602395412418_d89f68d1-7cf9-4dba-840b-1c392a54403c-image.png我没运行多久就出现这个问题了
    • 而且你用的是什么模型和label。是不是匹配的。
    • # CIFAR-10 Search Just Center Example
      # CIFAR is a convolutional nueral network designed to classify it's field of view into several
      # different object types and works on RGB video data.
      # In this example we slide the LeNet detector window over the image and get a list of activations
      # where there might be an object. Note that use a CNN with a sliding window is extremely compute
      # expensive so for an exhaustive search do not expect the CNN to be real-time.
      import sensor, image, time, os, nn
      sensor.set_windowing((128, 128))       # Set 128x128 window.
      sensor.skip_frames(time=750)           # Don't let autogain run very long.
      sensor.set_auto_gain(False)            # Turn off autogain.
      sensor.set_auto_exposure(False)        # Turn off whitebalance.
      # Load cifar10 network (You can get the network from OpenMV IDE).
      #net = nn.load('/cifar10.network')
      # Faster, smaller and less accurate.
      net = nn.load('/cifar10_fast.network')
      labels = ['basketball', 'volleyball', 'Football']
          # net.search() will search an roi in the image for the network (or the whole image if the roi is not
          # specified). At each location to look in the image if one of the classifier outputs is larger than
          # threshold the location and label will be stored in an object list and returned. At each scale the
          # detection window is moved around in the ROI using x_overlap (0-1) and y_overlap (0-1) as a guide.
          # If you set the overlap to 0.5 then each detection window will overlap the previous one by 50%. Note
          # the computational work load goes WAY up the more overlap. Finally, for mult-scale matching after
          # sliding the network around in the x/y dimensions the detection window will shrink by scale_mul (0-1)
          # down to min_scale (0-1). For example, if scale_mul is 0.5 the detection window will shrink by 50%.
          # Note that at a lower scale there's even more area to search if x_overlap and y_overlap are small...
          # contrast_threshold skips running the CNN in areas that are flat.
          # Setting x_overlap=-1 forces the window to stay centered in the ROI in the x direction always. If
          # y_overlap is not -1 the method will search in all vertical positions.
          # Setting y_overlap=-1 forces the window to stay centered in the ROI in the y direction always. If
          # x_overlap is not -1 the method will serach in all horizontal positions.
          for obj in net.search(img, threshold=0.6, min_scale=0.4, scale_mul=0.8, \
                  x_overlap=-1, y_overlap=-1, contrast_threshold=0.5):
              print("Detected %s - Confidence %f%%" % (labels[obj.index()], obj.value()))
              img.draw_rectangle(obj.rect(), color=(255, 0, 0))
    • @kidswong999 难不成不能改吗,emmmmmm
    • 可以改,但是你的mobilenet和lable不匹配。
