  • SD卡里图片是用openmv的VGA像素拍摄的,
    • 代码就是检测到有人,就把视线内的所有人脸与SD卡里的人脸对比,SD卡里图片是用openmv的VGA像素拍摄的,有90多KB。一读取就内存报错MemoryError: Out of normal MicroPython Heap Memory!。代码和要比对的图片如下:
      # Face recognition with LBP descriptors.
      # See Timo Ahonen's "Face Recognition with Local Binary Patterns".
      # Before running the example:
      # 1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip
      # 2) Exract and copy the orl_faces directory to the SD card root.
      sensor.set_framesize(sensor.VGA) # or sensor.QQVGA (or others)
      i = 1
      # 拍摄当前人脸。
          if not objects :
              print("no people")
              continue
          for face in objects:
              d0 = img.find_lbp(face)
              img = image.Image("%d.pgm"%i)
              dist = image.match_descriptor(d0, d1)#计算d0 d1即样本图像与被检测人脸的特征差异度。
              if dist >28000:
                  print("people is not match")
                  print("There's a match here ")
      由于不能上传pgm格式图片,我把拓展名改成了jpg格式,麻烦一下您下载后把拓展名改回pgm格式,然后试一下。谢谢!
    • 此回复已被删除!
    • 我测试没问题,固件3.6.4
      face.pgm就是你上传的图片。
