  • 怎么能很好的同时实现颜色识别和直线识别?
    • 进行的是红色的颜色识别,单独进行颜色识别或直线识别的话,是可以完成的,可是把代码放在一起,无论颜色识别还是直线识别都会特别乱,识别出一些不必要的东西
      enable_lens_corr = False
      import sensor, image, time, math,usocket, sys, json,socket,network
      threshold_index = 0
      thresholds = [(0, 100, 0, 127, 0, 127)]
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
      min_degree = 0
      max_degree = 179
       #   clock.tick()
         # for blob in img.find_blobs(thresholds, pixels_threshold=10, area_threshold=10):
          blobs = img.find_blobs(thresholds, pixels_threshold=20, area_threshold=20, merge=True)
              max_blob=find_max(blobs )
                  if blob.code():
              if blob.cx() > img.width()/2:
                  print(03)
              elif blob.cx() < img.width()/2:
                  print(04)
                  print(00)
              if blob.cy() < img.height()/2:
                  print(01)
                  print(00)
              if enable_lens_corr: img.lens_corr(1.8)
              for l in img.find_lines(threshold = 1000, theta_margin = 25, rho_margin = 25):
                  if (min_degree <= l.theta()) and (l.theta() <= max_degree):
                      img.draw_line(l.line(), color = (255, 0, 0))
                      if l.x1() > img.height()/2:
                          print(16)
                          print(16)
    • draw需要放在最后面,否则找直线会把手动画的框识别到。
