云台不动。照教学视频做的。示例代码只更该了红色阈值(LAB、RGB都试过了)或P、I参数,但是云台依旧没有反应。
请在这里粘贴代码
from pyb import Servopan_servo=Servo(1)
tilt_servo=Servo(2)
#只对这句话的数值按视频教程做出了修改(注释的是原有数值)
red_threshold = (0, 61, 31, 98, -128, 127) #(13, 49, 18, 61, 6, 47)pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
#tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PIDsensor.reset() # Initialize the camera sensor.
clock = time.clock() # Tracks FPS.def find_max(blobs):
return max_blobwhile(True):
img = sensor.snapshot() # Take a picture and return the image.blobs = img.find_blobs([red_threshold]) if blobs: max_blob = find_max(blobs) pan_error = max_blob.cx()-img.width()/2 tilt_error = max_blob.cy()-img.height()/2 print("pan_error: ", pan_error) img.draw_rectangle(max_blob.rect()) # rect img.draw_cross(max_blob.cx(), max_blob.cy()) # cx, cy pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output)
没有焊接插针。不可能动。
