代码没报错,但为什么一运行后云台会自动的一段一段往上走?这个要怎么处理呢?
import sensor, image, time, network, usocket, sys, json
from pyb import Servo
from pid import PIDpan_servo=Servo(1)
tilt_servo=Servo(2)pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
#tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PIDSSID ='OPENMV_AP' # Network SSID
KEY ='1234567890' # Network key (must be 10 chars)
HOST = '' # Use first available interface
PORT = 8080 # Arbitrary non-privileged portsensor.reset()
sensor.set_brightness(1)
sensor.set_saturation(1)
clock = time.clock() # Tracks FPS.uart = UART(3,115200)
在AP模式下启动wlan模块。
wlan.start_ap(SSID, key=KEY, security=wlan.WEP, channel=2)def start_streaming(s):
client, addr = s.accept()
# 将客户端套接字超时设置为2秒
client.settimeout(2.0)
print ('Connected to ' + addr[0] + ':' + str(addr[1]))# 从客户端读取请求 data = client.recv(1024) # 应该在这里解析客户端请求 # 发送多部分head client.send("HTTP/1.1 200 OK\r\n" \ "Server: OpenMV\r\n" \ "Content-Type: multipart/x-mixed-replace;boundary=openmv\r\n" \ "Cache-Control: no-cache\r\n" \ "Pragma: no-cache\r\n\r\n") # FPS clock clock = time.clock() # 开始流媒体图像 #注:禁用IDE预览以增加流式FPS。 while (True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot().lens_corr(1.8) for c in img.find_circles(threshold = 2500, x_margin = 10, y_margin = 10, r_margin = 10, r_min = 2, r_max = 100, r_step = 2): #threshold检测像素点大小,step渐增半径数 area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r()) #area为识别到的圆的区域,即圆的外接矩形框 x,y为中心坐标 statistics = img.get_statistics(roi=area)#像素颜色统计 #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。 #l_mode(),a_mode(),b_mode()是L通道,A通道,B通道的众数。 if 60<statistics.l_mode()<100 and -128<statistics.a_mode()<127 and -124<statistics.b_mode()<127:#if the circle is red img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆形用红色的圆框出来 else: img.draw_rectangle(area, color = (255, 255, 255)) #将非红色的圆用白色的矩形框出来 a = {str(c[0]),str(c[1]),str(c[2])} a_str = json.dumps(a) output_str = json.dumps(statistics) uart.write(output_str+'\n') uart.write(a_str+'\n') b=[] if uart.any(): a = uart.read().decode() for items in a: if items=='{': continue elif items=='}': continue elif items==',': continue else: b.append(int(items)) if b : pan_error = b[0]-img.width()/2 tilt_error = b[1]-img.height()/2 pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output) cframe = img.compressed(quality=35) header = "\r\n--openmv\r\n" \ "Content-Type: img/jpeg\r\n"\ "Content-Length:"+str(cframe.size())+"\r\n\r\n" client.send(header) client.send(cframe)
# 创建服务器套接字
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)# 设置服务器套接字超时 # 注意:由于WINC FW bug,如果客户端断开连接,服务器套接字必须 # 关闭并重新打开。在这里使用超时关闭并重新创建套接字。 s.settimeout(3) start_streaming(s) except OSError as e: s.close() print("socket error: ", e) #sys.print_exception(e)
