请问为什么我一与stm32建立起连接并且找到目标就开始掉帧呢
![0_1579411056541_U%DUWPEYA_JX(}P_7RBMZ2I.jpg](正在上传 100%)
c sensor, image, time, math, struct,random from pyb import UART red = (49, 97, -31, 67, 52, 94) red1 = (39, 100, 20, 127, -128, 127) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 10) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) clock = time.clock() # 串口初始化 uart = UART(4, 115200) uart.init(115200, bits=8, parity=None, stop=1) def find_max(blobs): max_size = 0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob def blob_sort(blobs): new_blobs = [] for i in range(0,len(blobs)): max_blob = find_max(blobs) new_blobs.append(blobs.pop(blobs.index(max_blob))) return new_blobs def send_message(blob): #for blob in blobs: x = int((blob.cx())*128/320) y = int((blob.cy())*60/240) z = int(blob.area()*(128*60)/(320*240)) num = 1 dateout = struct.pack("<bbhhhb", # 打包数据 0xaa, # 帧头1 0xae, # 帧头2 x, # 数据1 y, # 数据2 num, # 数据3 0xff) # 帧尾 uart.write(dateout + '\n') print(dateout) #将获取到的色块的坐标变为json json.dumps([max_blob.cx(),max_blob.cy()]) while(True): Location = [] clock.tick() img = sensor.snapshot() red_blobs = img.find_blobs([red1],area_threshold=10,pixels_threshold=20) if red_blobs: #new_blobs = blob_sort(red_blobs) #对色块的大小进行排序 #send_message(new_blobs) #获取排序后色块的信息并依次发送至muc max_blob = find_max(red_blobs) img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(), max_blob.cy()) send_message(max_blob)
什么叫做调帧?具体什么现象。
