  • 人脸识别为什么当我放一张风景照的时候也能跟录入的人脸库匹配上?程序就是用的官方例程,是精确度本身就这么低吗?
      Face recognition with LBP descriptors.
      See Timo Ahonen's "Face Recognition with Local Binary Patterns".
      Before running the example:
      1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip
      2) Exract and copy the orl_faces directory to the SD card root.
      #SUB = "s1"
      NUM_SUBJECTS = 6 #图像库中不同人数,一共6人
      NUM_SUBJECTS_IMGS = 20 #每人有20张样本图片
      拍摄当前人脸。
      #d0为当前人脸的lbp特征
      img = None
      pmin = 999999
      num=0
      def min(pmin, a, s):
      global num
      if a<pmin:
      pmin=a
      num=s
      return pmin
      dist = 0
      img = image.Image("singtown/s%d/%d.pgm"%(s, i))
      #d1为第s文件夹中的第i张图片的lbp特征
      print(pmin)
      print(num) # num为当前最匹配的人的编号。
