  • 色块寻找?求没找到色块发送个0?
    • # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      threshold_index = 0 # 0 for red, 1 for green, 2 for blue
      # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      # The below thresholds track in general red/green/blue things. You may wish to tune them...
      thresholds = [(30, 100, 30, 127, -40, 60), # generic_red_thresholds
                    (15, 40, -10, 40, -50, 20), # generic_block_thresholds
                    (60, 80, 0, 64, -10,40)] # generic_blue_thresholds
      sensor.skip_frames(time = 1000)
      # camera resolution. "merge=True" merges all overlapping blobs in the image.
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=400, area_threshold=500, merge=True):
              # These values depend on the blob not being circular - otherwise they will be shaky.
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255,0,0))
                  img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  img.draw_line(blob.minor_axis_line(), color=(0,0,255))
              # These values are stable all the time.
              # Note - the blob rotation is unique to 0-180 only.
              img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)
              print(threshold_index,blob[4])
          except NameError:
              print(1)
          threshold_index=threshold_index+1
          if threshold_index>1:
              threshold_index=0
      我是多色块寻找,返回色块颜色和大小,但是blob【4】这个变量无法更改,更改就报错,我试过del blob也没用,
      try函数是第一次没找到报错用的!
      最后效果想的是如果没找到色块,返回个0就好
      求大佬帮助啊
    • blobs = img.find_blobs()
              xxxx
          print(0)
