  • 有木有什么好方法分辨出红绿蓝白黑五种颜色
    • 黑白色块分辨时,如果只有黑或只有白时色块识别并没有工作是为何呢
      我红绿蓝用的是彩图色块识别,黑白用的是灰度
      黑白时总是只能识别其中一种颜色
      import sensor,time
      import image,math
      from pyb import LED
      kernel_size = 1 # kernel width = (size*2)+1, kernel height = (size*2)+1
      kernel = [-1, -1, -1,\
                -1, +8, -1,\
                -1, -1, -1]
      redthresholds = (29, 99, 19, 127, -128, 127)# grayscale thresholds设置阈值
      greenthresholds = (30, 100, -64, -8, -32, 32)
      bluethresholds = (19, 72, -128, 127, -128, -8)
      graythresholds = [(65, 128)]
      whitethresholds = (185, 255)
      blackthresholds = (0,20)
      roi=(60,40,40,40)
      red_color_code = 1
      blue_color_code = 2
      green_color_code = 3
      sensor.reset() # 初始化 sensor.
      sensor.set_pixformat(sensor.RGB565) # or sensor.RGB565
      sensor.set_framesize(sensor.QQVGA) # or sensor.QVGA (or others)
      sensor.skip_frames(10) # 让新的设置生效
      sensor.set_windowing(roi)
      clock = time.clock() # 追踪FPS
          image = sensor.snapshot() # Take a picture and return the image.
          blobs = image.find_blobs([redthresholds, greenthresholds, bluethresholds], area_threshold=100)
              print(blobs)
                  x = blob[0]
                  y = blob[1] #
                  width = blob[2] # 色块矩形的宽度
                  height = blob[3] # 色块矩形的高度
                  center_x = blob[5] # 色块中心点x值
                  center_y = blob[6] # 色块中心点y值
                  color_code = blob[8]
                  if color_code == red_color_code:
                      image.draw_rectangle(blob.rect())
                      #image.draw_rectangle(0, 0, 20, 20,color=greenthresholds,thickness=1,fill=False)
                      image.draw_cross(center_x, center_y)
                      output_str="[%d,%d]" % (blob.cx(),blob.cy()) #方式1
                      print(output_str)
                  elif color_code == green_color_code:
                      print(output_str)
                  elif color_code == blue_color_code:
                      print(output_str)
          else :
              img.to_grayscale()
              img.binary(graythresholds)
              blob = img.find_blobs([whitethresholds], pixels_threshold=10, area_threshold=10, merge=True)
              if blob:
                  print('4')
              else :
                  print('5')
