  • 按照人脸识别教程上面的方法改了云台的例程,发现云台不能进行人脸追踪,而且总是报这个错,这是为什么呢?
      以下是我改的代码:
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      red_threshold  = (13, 49, 18, 61, 6, 47)
      # HQVGA and GRAYSCALE are the best for face tracking.
          objects = img.find_features(face_cascade, threshold=0.90, scale=1.35)
          if objects:
              max_blob = find_max(objects)
    • @kidswong999 求大神回答。。。😢
