  • 我在运行识别矩形的例程时,发现rect.x()为负值,这是为什么?
    • 我在运行识别矩形的例程时,发现rect.x(),rect.y()为负值,这是为什么?
      代码:
      # Find Rects Example
      # This example shows off how to find rectangles in the image using the quad threshold
      # detection code from our April Tags code. The quad threshold detection algorithm
      # detects rectangles in an extremely robust way and is much better than Hough
      # Transform based methods. For example, it can still detect rectangles even when lens
      # distortion causes those rectangles to look bent. Rounded rectangles are no problem!
      # (But, given this the code will also detect small radius circles too)...
      sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
          # `threshold` below should be set to a high enough value to filter out noise
          # rectangles detected in the image which have low edge magnitudes. Rectangles
          # have larger edge magnitudes the larger and more contrasty they are...
          for r in img.find_rects(threshold = 10000):
              print(r)
          print("FPS %f" % clock.fps())
      运行结果:
    • 我测试了代码,不是负数。
      请提供你的硬件版本,固件版本,IDE版本。
    • @kidswong999 当我识别到多个举行时就会出现这负值
      如图
      硬件版本:
      是这个吧?
      怎么看固件版本啊?
      IDE版本
    • 我这里挺正常的。
    • @kidswong999 请问大佬知不知道产生负值的原因?
